Briggs & Stratton I/C 17.5 hp Model 31C707 0603 Repair Manual
chrisrhzg
  • / Briggs & Stratton I/C 17.5 hp Model 31C707 0603 Repair Manual
Hello All new to the Forums!
Was wondering if anyone could help me out with a repair manual for the Briggs I/C 17.5 hp Model 31c707 0603 ?
I am going to replace the headgasket and carb but dont know if there is a pattern and how much to Torque, also if I will need to replace the headbolts ?
Thanks,
Chris
Scrubcadet10
Moderator
Staff member
<wrong info>
chrisrhzg
Thanks!
Im not sure this covers my motor as idk if it is a twin cylinder but Ive yet to remove the head. But from my guess its only a single piston motor, only one spark plug ?
Scrubcadet10
Moderator
Staff member
Oh crap, that is the wrong model, when you said IC i assumed the opposed I/C twin. but they had a model number of 42 or 44, not 31. let me get you the correct one.
Scrubcadet10
Moderator
Staff member
Scrubcadet10
Moderator
Staff member
1682905029385.png Torque
Head screws (bolts) are torque to 250 in-lbs or approxiamtely 21 ft-lbs (20.83333 ft-lbs) but make the head surface is flat as they can be warped.
Winifred
Why can't I download the 31c707-0603-b2 repair manual?
