Briggs & Stratton 8250 storm responder carb bowl held on with Phillips head screws???
Forest#2
  • / Briggs & Stratton 8250 storm responder carb bowl held on with Phillips head screws???
For those who don’t know, there are 2 types of 4 sided screwdrivers. One is called a Reed and there other is called a Phillips. Difference is that the Reed style comes to a point and the Phillips has a flat end. Most people don’t know this ( even techs) and don’t use the correct one for the job.
Have you ever seen a Arthur Head screwdriver?
(very rare, possibly only 4 made from the A head of a typewriter key)
The A on the screwdriver fits into the A hole on the screw.
Made by Arthur Spooner OF THE KING OF QUEENS SHOW
You can review such on-line.
Never seen or heard of it. But I’ve never watch King of Queens.
Scrubcadet10
Moderator
Staff member
LOL!!!!!
"It fits into the corresponding A HOLE" :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Pepsidrivah
Well I started taking off the carburetor and am unfamiliar with the tool that I need to take the bolts off and hold the carburetor on. I know it's probably simple but every time I try to fix something, I run into something new. I'm open to suggestions on how to take those two bolts out so I can remove the carburetor and take the bowl off! Thank you in advance!
Auto Doc's
Those long screws (studs) that hold the carburetor on have a star on the tip that require an E-torx bit to take out. The studs each have a shoulder that hold the carburetor on.
A good pair of baby vise-grip pliers usually work, but damage to the stud will occur, so a proper bit is preferred.
Another method to remove them is called "double nutting". It is where you screw both air cleaner retainer nuts onto the stud with the flanged portion facing one another, tighten them against each other so they are tight. Then put a wrench on the one closest to the carburetor and back the stud loose.
Pepsidrivah
My photography leaves a little to be desired. The ends of those bolts are six pointed. My first thought is to just grab a hold of them with vice grips and turn counterclockwise. I don't know...
While I have the brain power focused in on something, what do you guys think about Westinghouse generators and or Duramax generators? Thank you!
Auto Doc's
Hi P.,
Please don't mix subjects.
Open a separate thread post to discuss portable generator choices.
Scrubcadet10
Moderator
Staff member
E5 external torx.. Harbor freight has em
Pepsidrivah
Just drove over and picked up a set. I shall give it a shot tomorrow when there is enough light. Thanks for everybody's help ‼️
