maddogandnoriko
- May 26, 2012
- 5
- 9
My neighbor asked me to see if I could get his mower to run for him and I said yes. He said the mower would fire up if he put a bit of gas in the carb then it would die. Sounded like a dirty carb to me and I proceeded to pull it off and clean it up. Sure enough the gas had started to turn to lacquer/varnish. So I cleaned it up with some gas and poked a guitar wire where I could. All looked good.
I filled it with clean gas and it fired right up. But about 3-5 minutes later it slowly wound down and died, sput sput like it was out of gas. So I refilled the gas to the tippy top and it fired up again and died again.
So I think it boils down to this...when the gas goes down about a 1/2 inch from the top rim of the gas cap it dies. The 1/2 inch is just below the 1/16 inch hole in the tank just below the gas cap. Looks like overflow or choke hold for gas or something.
I would appreciate any help I can get. And would also like to know the correct name of the little hole for overflow gas.
The engine is a Briggs and Stratton 6.75 HP with float bowl carb and no primer bulb. Fairly new with a key start. craftsman mower. Engine code#: 126T05-1071-B1 080 1956. Mower model #: 917.376480
Todd
Todd
