briggs quiet starting problem
Hey guys, I'm workin ona yard machines with a 14.5hp Briggs ohv single cylinder motor.....when I put my jumper/starter on the battery and try to start it the starter does nothing....I'm pretty good with motors and electrical wiring etc,but this ones got me stumped.....I even put jumper cables on battery and starter bolt to bypass safetys and such but still nothing any ideas? I havent looked at it much cause I haven't had much time lately....thanx, I'm new to this forum.
Remove the starter and check it out... It seems you have found that there is an open in it... Perhaps the brushes...? :smile:KennyV
It most likely won't be the copper post on the outside but, could easily be where that post continues inside the starter. :smile:KennyV
