i have a briggs and stratton 650 series quantum engine, only 2-3 years old, the engine would start randomly/once in awhile and other times would not start, this has been occuring for about 6 months, when the engine DOES start it will run fine till i shut it off, then will not start again until it has fully cooled down (the next day),
i have been slowly trying to isolate the problem, the carb is clean and fine, the choke is functioning properly, compression very good,
i have finally found the problem of a very weak or intermittent spark, i cleaned the flywheel and the coil assembly, and set the proper gap, still no improvement,
i took the coil to a repair shop and they tested it and said its fine, he even showed me while he was testing it with a spark tester,
the only thing left i can think of are the magnets on the flywheel, but i dont know how to guage if they are strong enough or not, i have removed the flywheel and there seems to be three magnets?
the middle/center magnet is VERY STRONG and will pull a screwdriver from about an inch away and hold it there, the two side magnets are very noticeably alot weaker, they will not pull the screwdriver in and will not hold a screwdriver by themselves, i notice a very slight attraction but definitely not as strong as the center magnet,
is it normal for the side magnets to be weaker like this? or could this be my problem?
i dont want to blow the money on a new flywheel if its not the problem
thanks in advance,
thanks in advance,
