briggs opposed engine
bebuzz69
i have a briggs 461707-0143-E1 and i took the carb off to clean it and now i can;t see how to put back on.
can somebody tell me where to get a good picture of the linkage setup..
i looked at the diagrams but they don't show where to hook up the black throtle plate on the carb.
You have a choke and a throttle plate. Should be a small hole you install the linkage rod into. Choke plate is AWAY from the engine block. Throttle plate is CLOSEST to the block.
Take pictures of what you have now. Post them here so we can see what you are working with.
