I've posted several items on here about the 15.5HP OHV engine I'm working on for my in-laws. I did a leak test on it tonight and found air coming out of the exhaust which indicated a problem in the exhaust valve. After pulling the head, I found that the exhaust valve seat had come loose from the head and was sitting at a 45 degree angle in the head were it is supposed to be installed. This kept the valve from seating. The seat looks to be in tact, I didn't remove the valve to check it yet.
Can I buy a seat from Briggs or are they built into the head? I just looked at a schematic and don't see a seat sold seperately. Also, is this something I can replace myself or does it have to be pressed in by a machinist?
