Hello!
I am currently trying to fix/rebuild a craftsman riding mower. The mower has a motor marked as a 10hp briggs and stratton engine. After looking around I found this was a tecumseh TVXL220-157245D motor. I decided to pull the motor off when the mower started to make a fairly loud knocking sound.
Given that this is a fairly old mower, I decided to tear it apart and fix it. {or try
} Either way...this is more for fun than anything else.
When I tore into the mower, I found that the old connector rod was is pretty rough shape and had a lot of slop. I ordered another connector rod and started to assemble the engine. Everything seemed to go back together right, but I noticed an oddity when trying to turn the engine over {by hand} If I cranked the engine in a counter clockwise manner, everything seems to work properly {piston/lifters/etc}. If I turn it clockwise, it will make one full rotation of the piston/lifters and then locks.
I then thought....maybe the starter would turn counter clockwise. As it turns out, I found the starter would turn the motor/flywheel clockwise. Does anyone have any thoughts on what I have installed wrong? I know another tear down is coming, but I figured I would ask first
