I have a Coleman generator I am fixing. It is a model PM0544502. It had a carburetor issue. Once I solved that I lost spark. Once I pulled the cover off the engine I found a stray ground wire contacting the cylinder head. Once I pulled it away from the engine it started, and ran fine. The model of the engine is 194412-1112-01. Here is a picture of the wire.
Does anyone have any idea where this wire may go? I noticed this generator has no on/off switch, or any other way to cut spark. Were any of these engines designed to be killed with the choke? Thanks for any help, I really appreciate it.
