Briggs and Stratton rocker arm problem
Popsplace
I have a 15.5 Briggs and Stratton engine that keeps breaking exhaust rocker arms what caused this and how do I fix this problem
It could be valve clearance is out or more likely to be the decompressor is broken on the end of the camshaft and not allowing the excess pressure out when on compression stroke.
Well couldn't read that post above but most likely cause is that the exhaust valve guide has moved up until the valve spring keeper is hitting it and breaking the rocker arm. NOT high compression. Briggs will say the cure is a new head but I have a tried and true fix used successfully by dozens of people. Check exhaust valve guide height against the Intake valve guide height. Valve guide should not be more than 1/8" above the head casting. IF you want my fix, address below, put in proper format and remind me engine model number and what you want.
Walt Conner
wconner5 at frontier dot com
PS: If that has happened, the most common cause is a cooling problem, plugged cooling fins and or cooling shroud.
