Briggs and Stratton 12HP trouble
07drummerboy
Hi
COME TO USE My Yard pro with a 12 HP Briggs and startton engineat the BEGINNING OF SUMMER
AND WOULDNT RUN
CLEANED CARB OUT THEN IT RAN
IT WILL TICK OVER ALL DAY BUT WHEN YOU REV IT CARB FILLS WITH OIL!
Has any one got any ideas on what the problem could be ??????
Cheers
check the oil level and make sure the crankcase is not filled with a gas/oil mixture due to the carb needle valve leaking gas into the crankcase.
