animattor
I was given a mower after it hit a large root and wouldn’t start any more. I have already:
-replaced the flywheel key
-Straightened the driveshaft (following Steve’s small engine saloon)
-emptied/cleaned gas tank and fuel line
-added fuel
-checked oil
-Disassembled carb and cleaned with compressed air (didn’t have carb cleaner)
the air filter is full of oil so I removed it and tried to start mower. It doesn’t catch, then “pops” with a little white smoke out of the carb. Repeated pulls just give this pop like a backfire, but it won’t catch.
I tried starting it with a tsp of gas directly through spark plug hole, and it’s the same. If I install the (old) air filter, I get absolutely nothing, so it seems like an air/fuel problem but I’m not sure what to try next. Should I try spraying carb cleaner or starter fluid in the carb?
Edit: I read about hydro lock and flooded engines, so I pulled the spark plug and cycled the engine several times. Now it no longer backfires but it still won’t catch.
-added fuel
-checked oil
