hatteras451
Could anyone help me with a carb problem...I have a Briggs 3hp on a Mclane edger. Carb part no. 397939. It has not ran smooth since I purchased it used. I have taken it apart and soaked in carb cleaner, blown out with compressor, put a new kit on (twice) and adjusted mixture screw. First, it is hard to get started. Most of the time I need starter fluid to get going. After warmed up, it cranks fine but runs very rough. It surges and sounds like it wants to cut off. Runs like there may be trash in it but I have cleaned it twice along with the soaking. Or either the mix id off which I have played with for quite a while. Is there anything else I can look at when I take it back off? Thanks
