dougand3
- Mar 10, 2012
- 12
- 437
Briggs 422707 18hp Opposed Twin in Craftsman lawn tractor ~ 1989 model. Got a new 3 lead solenoid cuz I was having hard crank issues and solenoid looked old and worn.. Briggs OEM 4441931 solenoid. Key switch to start gives a nice solenoid thunk but no starter action. Got 12.7v on battery side big terminal (constant). Got 8.9v on small terminal (key to start). 0 voltage on engine side big terminal (key to start). The key switch is new, too - old one was so loose inside that I replaced it.
Is 8.9v too low even with nice thunk? Bad solenoid from the factory? Thanks, Doug
