I am not familiar with that 3M paper.
It looks a bit coarse , you won't be able to use any thing other than the 220 grit and even that might create a problem holding the valve strait whie you rub it on the paper.
The glass sheet is to keep it flat and you saturate the paper so it sticks on the sheet of glass.
Old car windows are good for this, scraps of laminated shop front glass is better is you have any glaziers handy.
To do the exhause vlave you will need realy hard & sharp abrasive.
Which when yu asked is why I mentioned carborundam, which is a brand name for Silicon Carbide abrasive paper .
It is grey in colour.
And yes that looks like the right stone.
To give you a rough idea about 100 figure of 8 strokes on the stone will take about 1/10 th of a thou off the end.
SO for 0.006" off the end you are looking at around 6,000 strokes + or - which will take quite a while , hence the suggestion of putting on your favourite music finding some where comfortable and try to reylax while doing it.
The inlets will gring down a lot faster than the exhausts so start with one of them
