Mowing and it acted like it was running out of gas. I stopped and checked the gas. Gas was OK!!
It runs real slow like it is idling even when it is on full throttle. Cranks fast but won't start unless I add a small amount of gas directly into the carb. :frown:
Checked the air filter and gas cap for blockage. Everything fine.
What is the part (about 2" long) attached to the bottom of the bowl with to electrical wires running to it?
I vaguely remember a friend of mine said he was having the same type of problem and he replaced that part on the bottom of the bowl.
All information and suggestions greatly appreciated.
Ron
Model# 31C707 Type 0230E1 Code 0310102E
Ron
