Berniebac
- Apr 8, 2012
- 185
I bought a tractor last week for $50. I really just wanted the mower deck and the owner said it "threw the piston and broke the connecting rod.". That's all he said. So I get it home and the tractor is in really good shape and I thought why not investigate this engine to see if it could be made to run.
I took the hood and front grill off to get a better look at the motor. I also pulled the shroud. There is a lot of old oil on the front frame of the tractor, under the motor and just above the muffler housing. I wonder if the head gasket has been leaking for some time.
I looked the engine all over, still in the tractor, and could not find a crack or hole in the engine where the rod came through. I pulled the plug, shone a flashlight in the plug hole and could see the top of the piston. Spun the engine by hand and the piston did not move. I took a piece of dowel and pushed it in the plug hole and I could move the piston back with little effort.
There does seem to be a lot of fresh oil near the bottom of the engine, but the motor is full of oil. I suspect he filled it after it quit.
Briggs 16 hp, mod. 311777, type0209-E1, Code 011211ZD
My questions:
1) can the connecting rod break and not damage the engine I.e. not come through the side of the engine?
2) do you think it is worth trying to salvage the engine?
3) what should I do next?
Sorry, no pics, my computer is broke and I am on the iPad and don't know how to load a pic.
My questions:
