Chris_feldk
- Aug 19, 2023
- 2
- 12
Hi all, I have a Briggs 14hp ic I just swapped on a mower, carb was junk and unrepairable unfortunately had to get a Chinese one. Anyways the motor won’t rev past 2300 rpm and has very poor throttle response, if you put it to idle then wide open, it just falls on its face until it finally picks up. Been dealing it with a week and it’s got me stumped. I’ve adjusted the valves, new spark plug and gapped it. Gapped the ignition coil and made sure it had fresh gas. The throttle plate on the carb stays wide open but is only running at about 2300 rpm, the governor never moves. Starting to thing maybe the valves aren’t seating properly or need new intake gaskets but If anyone had any ideas that would be great thanks.
