Briggh & Stratton will not start
islandboy
I have a 2014 ariens lawn tractor (briggs & stratton engine) it will only start if i remove the air filter ang hold ny hand against th air intake..once starter it runs rough at first bou settles down and will continue to run until i shut it off...what might be the problem. mod nbr is 31R907
You don't say if the engine will spin over without holding your hand over the air intake or if it will not spin over unless you hold your hand over the air intake. Either could happen and it makes a big difference which.
Walt Conner
Engine will spin but will not start unless I put my hand over ihe air intake, once it starts, it will run until it is manually shut off.
Are you using choke while trying to start it? Make sure the choke is actually working. Does it spin over fast when if you don't put your hand on the intake?
Yes I use the choke, will have to check to make sure it is working...the engine spins the same whether my hand is on the air intake or not.
Sounds like you need to remove the carburetor and give it a good ol cleaning. It sounds like the low end passage ways and jet may be clogged. It will run fine after it starts with your hand over the intake? If so you probably have some gunk built up and it needs to be cleaned.
Thanks, the engine does suck my hand into the carb, so an air leak may not be the problem, I am going to do a thorough cleaning of the carb and see if thes will solve the problem.
Take off the air box and check to see if your choke plate is actually closing with the cable. If not then an adjustment is needed. Or it may be something more ~!~!
Hope this helps Mon Ami !!!!
