PTmowerMech
- Apr 16, 2018
- Threads
- 443
- 3,430
The fuel is a little mirky and seems have a bit of water it in. Also the fuel solenoid was bad.
You are forgetting the push galley on OHV engines that pass right the head gaskets. Briggs OHV Inteks are one that regularly blows the head gasket between the cylinder and the push rod galley.Where does the extra pressure come from, since the only way from the combustion chamber to the sump is either through the valve guides or passed the rings.
Stop & have a little think
As the pistons descend the crankcase is pressurised .
Air will take the path of leat resistance so it is simply a case that lifting the weight of the dip stick requires less energy .
The extra pressure comes from the crankcase area decreasing because the piston is traveling back down.Where does the extra pressure come from, since the only way from the combustion chamber to the sump is either through the valve guides or passed the rings.
Was the fuel solenoid actually bad or was it just needing a good ultrasonic cleaning?
That is IF it's blown around the edge, leading to the outside of the engine, right? Because the pressure inside the sump won't increase a whole lot, if it's an internal gasket leak. Will it?A blown head gasket will allow the crankcase to inhale much more air thru the leak on down stroke, so more crankcase pressure is developed.
Get an extractor (if you don’t already have one) and suck all that old bad cloudy fuel out, and blow out tank.That is IF it's blown around the edge, leading to the outside of the engine, right? Because the pressure inside the sump won't increase a whole lot, if it's an internal gasket leak. Will it?
Briggs don't normally fail from edges leading to the outside. I've only seen them leak between the valves and the opening to the push rods.
