Sailornels
In have a John Deere 737 with a 23 hp Kawasaki engine. Twice the oil filter has worked loose, dumping 1 quart of oil. I was using STP filters. I have now switched back to JD filters. The engine is smoking badly, not from the exhaust but from the cooling fins. Any ideas? Oil sucked up by the fan, or somung worse? If it is oil sucked up by the fan, how can I fix this?
