Blower won't fire
okieman
I have a Husqvarna 125b blower which fails to fire. I have tried a new spark plug and ignition coil. I also checked connectivity of the kill wires and switch. I had the new ignition coil replaced after a "no fire" condition. I have set the coil at .006 in (.005-.008 is what I believe the air space on the flywheel to be set at) and have tried "calling card" sized spacing
but still no fire. I have shot B12 into the cylinder prior to reinstalling the new spark plug (.024 gap); it should have fired. I've exhausted all my shade tree knowledge on this problem and would appreciate ANY help. Thanks in advance.
Have you made sure that you did not install the new coil upside down? Set the air gap at .010.
