I'm looking for a longer lasting blade. I have found a wider blade I can use but I'm afraid it will cause problems with my mower. Any suggestions?
Thanks for the replies. I've sharpened the blades a few times already. It works but as many yards as I cut i was looking for a better blade that last longer so I want have to sharpen or replace as much. I found out that a few people with the same mower I have use 3in blade instead of the 2 1/2in oem blade. I probably going to experiment with them to see how they work. That's only way to know for sure.
A 3in blade will last longer. U should be able to sharpen it a few more times because u got more metal so u should be able to get a few more uses out of it compared to 2 1/2in.
