BWH
I like to sharpen/touchup the blades every 25 hours, it works best to have a couple sets of blades to change out. I immediately soak the take off blades in a container filled with vinegar getting the gunk off helps keep them in balance better, then after 24 hours wipe them off and complete the sharpening maintaining the factory angle. Greasing is very important the best practice is to following your owner's manual using a premium grade of grease, over greasing can be as bad as under greasing. I have found the Oregon blades to be of good quality.
