Blades
Ojhooker
How often do you have to sharpen/ replace the blades on your mower??
How many hours do you have to grease all the pulleys ??
scott47429
that depends on if your using it for personal use or commercial use i sharpen my blades and grease every spring but i just use it to mow my own yard
The recommendation we give our customers (residential and commercial) is to sharpen the blades and grease the jackshafts every 50 hours. This may vary with your cutting conditions. Replace the blades when the back corners (wing edge) get worn to less than 1/16".
scott47429
well 50 hours is more then i use mine all year thats why i do it in the spring from start to stop of the mowing season i may have 30 hours on mine
That is why I said that this may vary depending on your cutting conditions. I probably should have added personal preference.
Ojhooker
What are the best blades to use ??I have some S6 on mine
Carscw
I do not sharping the blades on my snappers
After every two yards I use a file to clean up the edge. Keeps them sharp and at the factory pitch
On my reel mower I back lash every 4 yards
Sent from my iPhone using LMF
Don't know what an S6 blade is. If I don't use an OEM blade, I have found that Oregon makes a good replacement.
Ric
Well I start out the season with three sets of blades for both mowers and I replace blades every 36 hours and grease everything the same and sharpen the set I remove so there ready to be used again. So I guess your basically talking about everything being done every two weeks. The manual says to grease spindles every 25 hours.
Rivets is right about the back corners (wing edge) getting worn off, if you see that they need to go in the bin to be turned in at the end of the season.
Briana
Welcome to LawnMowerForum!
I moved your thread to the General Mower Discussion forum. :smile:
