Generally PTO clutches are hard wired on the power side & the switch makes a ground connection
Originally ground was made through the clutch body and you switched the power side but this proved to be unreliable
So if your coil has a short to ground then it can be energised all the time & the plug will throw a spark when you disconnect it .
Over tightening can also crush bearings so they will not rotate freely .
