In reply to others that posted after my last post, It is a 42in deck and yes it is a challange to get a good cut but has been OK.
I am cutting at 3in blade height because other wise I seem to get alot of burnt grass from the heat. I set this right at the blades as I know that the setting on the tractor does not jive to the right height, the deck is set to 1/8 to 1/4 differance front to rear (rear being high). Do you think that 3in is still to high ?? Another thing is that I don't seem to set the speed at the setting that they have on the throttle lever for cutting just always seems way to high. I do use that higher setting for the snow blower.
And also I do have a set of those heavier blades but those end up on the machine in the fall when we have alot of leaves. I tried them in the summer a few years back but didn't see a big differance in cutting.
