Then are you saying my MTD distributor sending out fake blades as Genuine MTD as the stamp info is on the grass side? It is the same on the 942-05052AGenuine part will have it's number stamped into the top of the blade.
Aftermarket blades usually stamp on the bottom along with the words "Grass Side"
have you been installing the blades up side down...Interesting .
All of the original blades I have fitted for anything were stamped on the top
All of the aftermarket blades were stamped on the bottom
I had assumed that original blades are likely to be fitted by a dealer who should know which way the blades go .
Now you are going to force me to check every blade to see If I have been delluding myself
If he is they won't need sharpening for a very long time....And if he counting on a dealer to know what he is doing he is kidding himself.have you been installing the blades up side down...![]()
