Blade Question
10ecfarmer
Its been raining a lot here and the grass has a lot of moisture in it, I mean the grass is Sloppy wet.
So my question is, what type of blade makes the coarsest cut? The opposite of a mulching blade.
The available blades for my mower are:
a. parallel uplift,
b. low uplift,
c. corner uplift,
d. parallel uplift w/ cutout.
per the parts catalog.
Appreciate your time , thanks in advance.
If your mowing in wet conditions, I'd say you want the blade with the most lift. Avoid the mulching blades as they will just clog up your deck.
I forget what the cut-out gains, I would be looking for a straight high-lift thick HD blade, what I am assuming your calling a parallel uplift blade.
