Blade control cable
ron815
I've got a Snapper model 7800948-00 push mower and am having a hard time with the cable. I've got it connected at the motor but having trouble with the clip where the wire and bail connects. If I could see a picture of how they are connected to the clip would help a lot. Thanks.
Your cable has a "T" end? if it does the silver bracket on the bail has a hole and a notch. One end of the "T" goes in the hole first. The the other side slips into the notch. You have to remove the bail to insert the cable.
