Thin & Crispy
- Jun 9, 2019
- 9
Can you please tell us what model your Ferris mower is?
You need to be careful at "Best of XXX" lists. I do the same and I've found that companies pay people to get good reviews. Just be careful. Let the buyer beware.I Use https://duckduckgo.com for searches.
I bought a Ferris 400 S residential mower last year for my 2 acres.. It is a great mower, highly recommend. You can also look at the Kubota and Scag which were also on my listSo I'm looking for a Zero turn Mower and started reading posts on here.
But I also using the internet for research but every time I try searches like Best Zero Turn Mower 2017 or 2018 I get results of
Poulan Pro
Husqvarna
Troy-bilt
Most of these lists don't even show brands that everyone is talking about on here like;
Gravely
Hustler
EXMark
Toro
Why don't these brands show up?
you won't go wrong with the Ferris 400s. Mine is a 48" deck and I 've had it about 10 months. No complaints.Well right now I definitely like the Radius E over the Hustler Raptor SD
Hard to compare to the Toro since I only looked at the MX4200.
I need to go to another Toro dealer which will be closer to where I will live, and also go to the EXmark dealer close to my new home to check out there facility and service.
I would also like to check out 3 other dealers near there that sell SCAG, Gravely, and the last carries both Ferris and Snapper. I don't want to rule these mowers out without at least checking what they have to offer.
And also see the service they all provide.
I'm probably going to stick with something between 48" and 54" deck. And the deck has to be a Fabricated Deck, not a stamped deck
Yes, no dealer in my area either, for any of them.you right they are good mowers but there is no dealers in the area where I live and don't see them, years ago I worked on one with the out front mower, it was a nice machine, glad for you, Joe
I had a Hustler Sport 48" for 7 years, no major repairs...changed oil, blades, and filters, greased a few points. Decided to replace, looked at Hustler Raptors, was NOT impressed with the decks. Looked at a lot, but settled on a Graveley ZT HD 54" 3 years ago. Other than regular maintenance, it's worked perfect. The 5.5" derp deck works in all sorts of grass, even making damp mowing Ok. The unit weighs a lot more than the Hustler, the Kawasaki engine provides more than enough power, and the extra width makes it a LOT more stable on hillsides and ditches.Well right now I definitely like the Radius E over the Hustler Raptor SD
