LarryJohnson
The B&S V-twin that I brought back to life last year and used all summer is acting up. I sounds like someone is killing a cat when the key is turned. I used it once this year and started it sunday, but I had to turn the engine by hand a couple of time in order to get the starter to spin it. Seemed like there was a dead spot where the starter wouldn't crank it over. Is this the sound a weak mower battery makes?. It's not your typical, click, click click, like a weak car battery. Battery was in the house the last half of winter.
Won't be able to look at it until this weekend. Just wanted some ideas to kick around. Is another valve job needed? Thanks.
Last year, did the following to get it running and maintenance; valve job (my first), new starter, starter solenoid, wiring harness, battery, plugs, air filter, oil, oil filter, gas.
