I have a Honda HRC216, it will not start. The compression is very low so i took the valve cover off and found an issue. I am trying to find out what is going on. Any advice would be helpful.
Adjustment became loose...push rod slipped out of place and became bent in the process.
Hopefully nothing else was damaged.
Get a new push rod, install and adjust valve per specs.
I have never dissassembled an engine to that point. I guess u gotta start sometime
So I got a straight rode and started to replace the bent. I found another problem, seems the top valve is stuck in place and doesn't move. Any idea what could cause this? Or if I am doing something wrong? Thanks
