how do i tighten the belt tension on mower deck of a john deere l120 lawn tractor?
Z zebop Forum Newbie Joined Aug 7, 2011 Threads 1 Messages 1 Aug 7, 2011 / belt tension #1 how do i tighten the belt tension on mower deck of a john deere l120 lawn tractor?
JoeM(GA) Well-Known Member Joined Jul 10, 2011 Threads 0 Messages 191 Aug 7, 2011 / belt tension #2 you don't. the spring provides the necessary tension to the belt. If your belt is loose, the belt is worn out, the spring is loosing tension, or the tension idler isn't moving freely
