Beginner Question
robertos
I have a 4 stroke Craftman's lawn mover and after having troubles I removed the "container"
which holds the floater of the carburetor.( to clean it )
The bolt to remove shows a tiny sort of "extension" with a small diameter hole going across it.
I cannot figure out what the purpose of this hole is as it is not connected to anything and
would appreciate if anybody can help me.
That is the main jet. Clean it and make sure that the hole going down through the middle and side to side are open, then reinstall.
