Bed Armor on underneath or deck
BlazNT
Ok so with the new deck I got I decided to put something on the underneath of the deck to see if grass would not stick as much. Settled on Dupla Color Bed Armor $11.99 at auto parts store.
Sanded deck for Bed Armor to stick. Cleaned with pre-paint cleaner.
I will post pictures of underneath of deck after I mow tomorrow. Should be about 1.5 acres.
I am very interested to see how it does after several mowings without cleaning. I have heard of several different methods used to keep grass from building up under the deck, but that is the first time I have seen your idea. I hope it works, because I will be doing it to mine if it does.
I have used spray on undercoating on several decks. It not only helps prevent rust but makes the deck quieter and helps prevent the grass from sticking.
Done putting it back together. Well I was done 6 hours ago.
