Bearing
klink54451
I need to find a bearing for my Dixon ztr 7525 that i have had for long time. the bearing i need is discontinued every where i look. It is the top and bottom bearing that holds the wheel shaft to the frame. I have got part number 5391277-76 and also 60015 and also 3890. But they all are discontinued and now i am not sure which one is the bearing part number at all. ANt help of where i could find some of these bearings would be great. I have attched the picture of which bearing i need.
Thanks,
Auto Doc's
Look up Bohls Bearing in San Antonio TX, they can match anything you have if you provide a sample. I've used them for years to come up with odd bearings for all kinds of equipment.
klink54451
thanks i will try them
3890 crosses to 539115750 > 539112660 Flange Bearing and they are available. Alternates Rotary 6534 or Stens 230-237. 1" ID x 2" OD x 9/16" height
539127776 and 60015 are not bearings but are bearing shields used on the front wheels to cover those bearings. Now those shields are not available.
