Battery charging to almost 15 volts.
LaWn GuY
reynoldston
Yes 15 volts at WOT (Wide open throttle) would be normal. When the mower is just sitting without the engine running you should get around a 12.5 reading. The only way you would get high battery voltage readings WITHOUT the mower running is if there is a short in the battery. You might want to put a thinner weight oil in your engine for the winter months and turn the headlights off which will help with your starting. I plow snow with my ATV and run synthetic 0W-40 in it.
LaWn GuY
Ok guys I appreciate the replies but It was a typing error. I meant a tad over 16 volts.
Again,
with a flat battery fine
still doung 16 V 15 minutes latter and you might have some troubles.
reynoldston
Nothing to worry about even after the 15 min running time. Check your voltage after it sits over night not running and it should be in the mid 12's.
Mad Mackie
A correctly functioning charging system that is in the 10 to 20 Amp range and regulated, operates at 14.2 to 14.5 VDC.
Make sure that your test meter is operating correctly and use another meter for comparison before you make any decisions.
Get the correct specs for the charging system on your engine and check the system.
Charging systems of this type use a stator which is it's primary source of electricity and produces alternating current when the engine is running.
As the stator output is AC, part of its output is the wrong polarity. The regulator/rectifier, the next item in the charging system, blocks the part of the AC that is the wrong polarity. The part of the AC that is the correct polarity is then regulated and sent thru the electrical system ultimately ending up at the battery. These systems are known as half wave and produce pulsating DC to the electrical system and the battery. The battery has sufficient internal capacitance to turn the pulsating DC into a smooth wave of DC.
