Arnezie
Am I the only one who can't see the stripes ?Got some stripes and new employee I gotta remove the strip 1 more tme it's still a little to long
Y is badboy left out? I just bought one it's built better than mowers 1000 more expensive? Just don't. Get it
I have an early model (2005) AOS with a 72" deck. I purchased 3 used from a local commercial mowing company and then resold 2 of them. The one I kept had 1300 hours on it. It now has approximately 1800. I mow 5 acres. The cut quality stinks. I often have to go over it twice. I've tried a variety of blades. I find the meg-mow blades to work the best, but they are a pain to sharpen. The non floating deck scalps on nearly any small bump that a rear wheel dips into. It tends to eat deck drive belts. Parts are hard to get. Part numbers are hard to find as their online PDFs don't show my year and the newer models are different. A neighbor bought one from me and he has the same complaints. That all said, it is very fast to mow. If the grass is short and can be cut properly without going back over it, it works great. Mine has a 31 h.p. Vanguard which has plenty of power to swing the 72" deck. The blade speed is good. The mower deck is well built, but doesn't cut well. I think the heavy weight of this mower also contributes to the cut quality. The wheels leave a heavy imprint due to excessive weight which causes the grass to mat down where the wheels travel. I'm ready for a different mower.
I took a look at the pics in your link....VERY NICE machine you have in that Lightning Z and a nice striper kit(and professional striping cut)!!!! Unfortunately they no longer make your model and I think it evolved into the Outlaw XP. I considered the Outlaw, but all of the reviews at that time(Fall of 2012) were mixed(some had your experience and cut results and others were like user rvtech...hated the cut). With such "mixed" reviews I found it difficult to take a chance that I would get one of the "good ones".I've heard similar complaints on the older models. I believe they also redesigned the deck with mine? Not positive but I think so. I do know they revised it further going from mine to the brand new models. Mine actually has a floating deck using adjustable arms in front and it's hung from chains on back. 72" decks have a tendency to scalp anyway due to the size. If you cut short and hit any unevenness you will more than likely end up in that situation. As for blades, give the Oregon G6's a shot. I've done extensive testing (I can post another link from Lawnsite) and they by far work best for evenness of cut and disbursement. Also take some time to make sure your deck is level (side to side) and pitched 1/8-1/4" down in front. This will aid in suction and also cut quality. Sorry to hear of the issues, hopefully these tips may help you out.
