Badboy outlaw 2012 model
DAlawns
I have a female connector for the button that engages the blades that is damaged, they say i have to buy the whole wiring harness close to 300.00 dollars it is a 6 pin connector.
has anyone had this problem and where could i buy this connector without having to purchase the whole harness.
your help appreciated.
Just splice the wires yourself, they sell 3-4 and probably multiple pin connectors at the auto parts house, just buy the female and it's counterpart male.
IF post the mowers serial number of the mower so I can see what the connector housing looks like as may be something I already have a PN for or can figure it out.
A picture of the switch and connector housing also would. Just not it needs reduce to 1000 x 1000 pixels or less for this site to accept it.
Also the spam about the escort service has been reported and may have already been remove.
A little more research show you have a PTO like this one.
If so Bad Boy PN 070-2008-00 is their replacement part kit for the connector.
Now of course you will also need some heat sealed butt connectors.
Some of these switches have dual contacts and only one side is used , you can move the wires over to the other 3 contacts and it works fine.
Hey StarTech that looks like what I need Thank you!!, I kind of rigged mine it was on the end the yellow and orange wire which is yellow power, and orange to the Magnetic clutch, found some insulated female terminal connectors and i took a utility knife and cut the two sections off and plugged the remaining now 4 wire connector to the switch then plugged these two terminal connectors to the switch and taped them to the 4 pin connector for stability and hopefully they won't vibrate off. Thanks for everyone's help.
