Bad Boy 2010 4200 MZ zero-turn mower stops
Ted_S
Bad Boy 2010 4200 MZ will only start with parking brake Off and I have to jump solenoid. ?
I mowed my front yard and then moved to back yard. But now when I engage PTO/Blades the mower dies. ?
I can still start with brake Off and crossing solenoid. ?
After you get it started...what happens if you lift your weight off the seat?
I've jumpered the seat switch.
It doesn't do anything with brake engaged and key turned to start. I have arms out and checked that safety switches are pressed in.
I was surprised that it starts and runs with brake off and solenoid crossed.
