S sippi123 Forum Newbie Joined Sep 7, 2018 Messages 3 Sep 7, 2018 #1 MTD backfires sometimes while starting but not every time.What could be causing that.The motor is a16.5 Briggs ohv.
Boobala Lawn Pro Joined Feb 15, 2015 Messages 7,000 Sep 8, 2018 #2 sippi123 said: MTD backfires sometimes while starting but not every time.What could be causing that.The motor is a16.5 Briggs ohv. Click to expand... Back-fires are USUALLY, .. a timing issue, check your flywheel keyway, and check your valve adjustment also.
S sippi123 Forum Newbie Joined Sep 7, 2018 Messages 3 Sep 9, 2018 #3 I have set the valves at .004 ,I will check the kway.Thanks for the info.
