- Nov 29, 2014
- 24,995
Peak torque on these engines is usually around 3000 rpm
The engines are balanced for 3600 rpm ( roughly ) and at speeds above 4000 rpm can shake very badly
Connecting rods are weak and most will break when you try to run them above 5000 rpm.
If you disconnect the governor , leave the governor arm in place & hook a spring onto something to hold the arm back.
Inside the engine the governor mechanism can fall apart if there is no load working against the bob weights .
When these engines are converted for racing or go carts the crankcases are pulled apart & the entire governor is removed but the oil splash paddle wheel ( If fitted ) must be retained .
If you are going to use this engine for some sort of tractor then setting it up for normal governed control with a throttle over ride is the best way to go , not a direct throttle
Most tractor attachments are designed to run at either 3600 rpm or 1750 rpm and this has been the case world wide for at least 60 years.
Please tell us exactly what you want the engine to drive & what the machine will be needed to do .
I think all that you will really need is a couple of different springs to allow the engine to rev slower and a throttle cable with a lever at the dash board .
I gather you get this engine cheap and want to use it to power a tractor of some sort to do some farm work of some sort .
If this is the case there is no use making the engine go faster than 3600 in fact it will run bad use a lot of fuel and do a poor job.
The exception is if you want a faster road speed where there is little load on the engine but even then a higher gear to go faster with the engine spinning at 3000 rpm is better than making the engine spin at 4000 rpm .
