M Mini Motors Well-Known Member Oct 31, 2011 #11 It does sound like hydrolock, though. Gas should not be spraying out with the plug removed when you crank it.
P princeal Member Oct 31, 2011 #12 is there anyway it could be a weak starter that is too weak to turn over when under compression?:confused2:
