Geochurchi
- Aug 16, 2021
- 23
- 69
Hi All, I have a B&S 10T802 0547 B2 engine, on a push mower, it has no power, fresh gas, new plug, clean air filter, under deck clean, seems like the governor is not working correctly, it has been adjusted per specs , no springs involved just a straight rod from carb to governor shaft.
almost seems that governor is working in reverse, will accelerate manually if I move the throttle.
Geo ??
Geo ??
