websterelec
I have a Scott's L2548 riding mower with an Intek model 445777 25hp motor. I've noticed it smoking and found that oil is leaking from somewhere. I have virtually no experience with small engine repair, but decided to try to find and fix the leak myself. After reading online that the head gasket is a common problem, I removed it for inspection.
I've attached some photos, sorry about the quality. I expected to see a break or a thinning of an area in the gasket, but don't.
Is there another area that I should be looking in for a leak?
I should clean everything up with a wire brush before installing the new head gasket, right? I'm not sure where to look for a torque spec or the proper pattern when tightening everything up after installing the new gasket. I haven't received the new gasket yet and am hoping that there may be some instructions included.
Thanks for any advice.
