Geochurchi Active Member Sep 12, 2021 #1 Hi All, there are 2 wires on this magneto, 1 goes to ground terminated right on the mag mounting screw, where does the other wire connect? 1 obliviously there is the plug wire there also. Geo??
O olgeezershonda Well-Known Member Sep 12, 2021 #2 When you say "this magneto" do you mean it's different than the old one? What model and serial number is it going on?
Scrubcadet10 Moderator Staff member Sep 12, 2021 #3 Gonna need the model and type and numbers of the engine
Scrubcadet10 Moderator Staff member Sep 13, 2021 #5 Not coming up with anything on those, should be in the format of xxxxxx-xxxx-xx https://www.jackssmallengines.com/jacks-parts-lookup/briggs-stratton-model-locator.aspx
Geochurchi Active Member Sep 13, 2021 #6 Hi,probably because it’s an old model, I think I figured out . Thanks Geo ??
Scrubcadet10 Moderator Staff member Sep 13, 2021 #7 Old models are usually stamped around the spark plug area, flat heads.
