B ba_50 Well-Known Member Joined Jul 9, 2014 Messages 132 Apr 24, 2020 #1 020909 fe 120402 0213 E1 This horizontal shaft locks up after 6+ pulls on the recoil starter. The oil level and starter is good. With the shroud off the flywheel can be turned backwards then will turn
R Romore Well-Known Member Joined Jan 19, 2019 Messages 260 Apr 24, 2020 #2 Sounds like it is flooding.Do you get a spray of gas if you remove the spark plug and pull the cord?
B ba_50 Well-Known Member Joined Jul 9, 2014 Messages 132 Apr 24, 2020 #3 It wasn't getting any gas at all, just the carb spray I put in. Pulled it 12x with plug out. It didn't jam. No fuel coming out. Tried some carb spray again and got it running. Too much the first time I guess.
