ehl
- Feb 15, 2017
- Threads
- 3
- 9
Hi all ive worked on a lot of different briggs motors but never had this much trouble with an engine.
Its a 17.5hp intek 31G777 motor fitted in a ride on mower. Ive replaced the con rod and cam shaft,
timed it up all ok like I normally do set the valves up but no start.
Its backfires through the carb and wont have it at all, tried narrowing the clearance on the inlet to
compensate for the combustion release and its doing something because the exhaust is warm.
Any ideas where I should look next???
John
John
