B & S Flywheel Magnets
Gunnar Storsveen
Briggs & Stratton Flywheel magnets:
Are there one or tree magnets and which POLE orientation?
See appended 2 files
  • Brigs and Stratton Magneto System.pdf
Auto Doc's
We need a picture of the flywheel for reference. There are different designs.
What engine number is the flywheel on?
If it is only for triggering the coil, I don't think pole direction is important. If it is the magnets attached to the underside inner portion of the flywheel then the poles have to alternate between N. & S. polarity.
Type this into your search engine and I’ll bet you’ll find the answer to all your questions. how do briggs ignition systems work diagram
